The stock fasteners are M6-(1.00) x 40mm. If you wanted to go to actual push pins you would need to drill the threaded bracket out to accept (probably?) a 1/4"x1.5in Push pin. The bracket is cheap so you could even buy a spare to experiment with! McMaster carr also sells Metric Push pins but since the seat bracket is threaded already it is just an added expense. One other thing, is that they also sell an item called an "add a knob quick release pin", that you can put whatever 1/4-20 knob you want on it. And they are cheap!
