With that much extra wheel base, you won't be doing anything but spinning with the crap factory tire. The factory BS are junk anyway and by pushing the tire that far back with no weight over it, just makes it worse. Change the tire to something more performance related and you'll be a lot happier
would pilot ones be the best choice?
What is your intended usage of the bike?
You mention traction, are you intending to race or are you spinning the tire while riding the bike "normally"?
SInce this is the dragrace forum, I assume youa re planning to race, in which case, put a tire on it that is suitable for drag racing.
Shinko Hook-up for the most realistic street traction
Stealth U-Soft or Michelin Pilot power 1 (if you can find one) would be the next step lower for street tire traction.
You can go to a true roadracing tire as well, even getting used take-offs from roadracers.
Depends on what you are trying to do with it. If you are just posing with the bike and cruising around, leave the stock tire on so you can do rolling burnouts all of the time.![]()
mostly street racing. maybe the drag strip occasionally. the loss of traction now is manageable . just looking for some advice. this is really a great forum. I will look into getting a shinko hook up
