running,, sorta
newbe
I finaly got it together & started up but the right side exaust pipe blows harder & alot hotter. seems to run good otherwise but runs hot quickly. any help anyone?????
newbe
fan isnt comin on & gage dont show hot , gonna try changing the temp sensor on motor & maybe thermostat. I wired the fan direct & tried it , still ran hot. is it normal 4 the 2 pipes 2be different temps?
newbe
got the gauge 2 work,thermostats good,gonna work on fan 2marrow. sure has been a long road (tedious)!!!
bad4good
the exhaust pipes should be the same temp... clean the contact pins for the thermostat.. if you remove the thermo stat check its operation by putting the probe in boiling water should trigger it to work.
Back flush the radiator if stood around and not run for awhile, checking for leaks and any hot cold patches on the radiator. The bikes generally get hot quickly & normally the gauge indicates mid way on the scale.
If this bike been off road for a while when you test it on the road check the temp of your disc brakes are they all same temperature, discs should be between 4.5 and 5mm thick.
Latest Bikes
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
  • My 2014 Hayabusa
    • Dljat2
    • Updated:
  • Hi Everyone
    Loved
    • BirolBora
    • Updated:
  • 3-wheeler Touring Car
    2002 BMW K1200RS built into a Grinnall Scorpion 3 800lbs 130hp
    • K-Clive
    • Updated:
Forum statistics
Threads
174,130
Members
48,262
Latest member
Jbooges1
