you may have a wiring prob dude . If yer down in 'Bama , that should be warm enuff for it to come on .I am having a problem with the Busa running hot when I am not moving. I replaced the stock fan with a Muzzy fan and I noticed that the fan never turns on. Can anyone give me any suggestions as to what might be the problem?
yupThanks guys.
Is the switch mounted on the top left of the radiator?
Cool (no pun intended).EAKbusa,
The temp gauge went almost to the red and the fan never came on. While I was changing the stock fan out I also changed the oil and replace it with Amsoil.
rubbersidedown,
Thanks for the info. I will give the header tape some thought.
did you test it electrically ?After I installed the muzzy fan I made sure it was turning with no problems.
Take the connect off from the fanThanks guys.
what happens if he holds it in his right hand? heheheheTake the connect off from the fanThanks guys.
Hold the connection in your left hand
Take a paper clip and hold across both contacts while the bike is on running. If fan is working it wil come on.
If it comes on then it is your thermostat
If it does not come on check your connections to the fan.
The fan should be coming on with the Temp gauge 1/32 above the mid line
