With standard sprockets I run 10.500 rpm in 6th. (Airbox mod ; Vance & Hines tail- no mapping) Kindly let me know what sprocket changes you have made and what your 6th gear top end RPM's are. There seems to be a strong leaning to a 16 tooth front sprocket. Then there are others that go 2 up at rear.
A comparison will be interesting.
Thanking you
Hi Frank;
No - its not the Colin you think it is. I have seen your name on many topics and have seen you are quite an expert with bikes and inparticular the Busa. If I recall you are running with 2 teeth up at rear. What is your top end RPM? Thanks
