I'm been having more than a few late nights with my eyes glued to this forum, so I'm aware that there are a lot of you Hayabusa gurus out there . I fabricated a Hayabusa powered off-road car and nearly worked out most of the chassis bugs and am now ready to move on to supercharging the engine... I'm more of a fabricator than a engine guy, but I am almost finished reading the book "Supercharged" and now have a little bit of book knowledge. I really could use some help setting up my system. Can any of you comment (e.g. revise, advise, clarify , etc) about my scenario? lease:Am I missing anything important? I just got a great deal on a Rotrex 38-81. I am going to build a pulley shaft and supercharger assembly off the generator rotor basket/shaft. Like many, I am on somewhat of a budget so unfortunately, price is an object. I spoke with Richard over at TTS performance who was a big help. I did not want to eat up to much of his time, so I am still a little unsure in areas. A major thank you in advance for any amount of information large or small. At this point I'm looking at the below scenario:
Oh yeah, what I'm scratching my head over now the most is drive pulley size or pulley ratio (currently have 100mm on SC).
Current Specifications-Car weight: 1,300 lb
-Fuel Octane: 91 Absolute Max
-Current motor: Stock Hayabusa
Changes-Supercharger, SC: Rotrex 38-81
-Intercooler as large as needed
- Horsepower limits Low/High: 290-340
-9:1 compression ratio
-18 lbs boost
Engine Modifications-JE Turbo Pistons
-Cylinder bore Spacer 80 thousandths
-Austrian Built H-Beam conrods sold on Ebay
-APE cylinder studs and spacers
-Richard advised against Crankcase studs and nuts:
- Cometic head gasket torqued at 65 lbs:
-APE Clutch Springs
-Adjustable Cam sprockets
Fuel and computer-Stock ECU & ECU Editor retard timing 10-20 degree at top end (Richard stated to start at 16 degrees)
-Power commander III USB (which I already have)
-Siemens 650cc injectors
-Ignition Amplifier
-Disable map sensor and utilize throttle position sensor
-Rising Rate Fuel Pressure Regulator with needle valve
-Fuel Pump max pressure 60 lbs or less
Thanks Again! Danny
-18 lbs boost
-APE Clutch Springs
-Ignition Amplifier
Thanks Again! Danny
