I like it. Tired of having to install my NY disc lock from Krypto.
I am curious though, as you say it will now only fit 08-09 Busas , is that because mounted the pin specifically lines up with hole/holes in OEM rotor ?
Is it spring loaded so you don't have to roll bike back and forth to find that perfect spot for pin to go thru ?
I am thinking maybe once you unlock it you just have to move bike a bit and pin pops thru or does key action push pin thru ?
What happens if you have diff than OEM rotors ?
From pics in scars write up it looks like you just kinda eye/line it up and insert pin once you have unlocked it with key ?
