Just yanked my break pads and shims and now the new pads won't fit in... Do I need a tool to compress the piston? It looked simple in the manual but for some reason I am stuck... The pads are Ebc FA 63HH,,, Any help would be aprreciated.
well, if you didn't compressed back the pistons before you take out the old pads...then you can press back with your hands...you just gotta take the caliper off from the swing arm...(watch out for other pistons coming out...)
and are you sure you got the same parts? compare it between the 2 pads...
i use a C-clamp too get them back in there. worked for me. you can try loosening the bleed valve if it still wont go back but beware, you will have fluid come out and youll have to bleed the brakes.
You should bleed some fluid every time you replace brake pads, instead of compressing the fluid back into the system. Not doing so can introduce contaminants (usually little bits of dirt) that can dammage the system.
