blacknight
Just out of curiosity.
Is it fairly simple to remove the speed limiter on my 08 busa??
Busaj84 none of this stuff is necessarily connected. whatever the rev limiter is set to the PCV should work, however if the rev limiter is set to 11,500 the ecu would have to be flashed I think (isn't stock 10,500?). How do you know the rev limit setting without looking at the ECU?
That helped alot thanks guys
A flash will adjust your fueling. That is what a PC5 is for. NOT the same thing though. If you have fueling flashed, you are having the fueling for a different bike with different mods hardwired to your ECU. If you have a PC, the fueling can be easily changed by anyone with a computer. You can tune the fueling yourself with Autotune but you will have to do a fair amount of illegal riding to get the whole powerband mapped. You can have the tuning done a dyno and skip the popo risk.The PCV does what ECU flashing does, however ECU flashing offers access to many things the PCV does not.
I do not have either of my bikes flashed yet but when I do, I plan to have the stock fueling left alone and continue to use my PC5 for fueling. I'm sure the maps the flashers have are very good. People seem very happy with them but like I said, it's NOT really a custom tune for your bike.
PS--I like Bazzaz products better for a busa (Bazzaz also makes a module for self tuning similar to DJ's Autotune). Not much difference but the Bazzaz fuel module will accomodate 8 injectors instead of just the 4 primaries. PC is fine for Kaw but if you have 8 injectors, don't you want to tune all of them?.
I have 08 and when i got the bike i notice my rev limiter was 11,500 or more i recently bought the pcv wanted to know if it will be of any use
