jeremy_283
I need to install my HIDs and was wondering if I can remove the nose piece without removing the fairings?
Yes, but there's only a few bolts left holding the fairings on when you do it this way. You don't have to remove the nose to install HIDs.
I did it with the nose still installed. I'm not convinced it made it easier.
If you remove the guages and trim and the plastic splashguard under the nose it's as simple as changing bulbs. The ballasts are easy to mount on the right(right when sitting on bike)ram air tube with room to run the wires.
do the new hid bulbs just plug right into where the old bulbs went?
