I will try to take a pic, his stand has the whit "arm" which rests on the ground and a long metal shaft , he has an R 1 and takes the shaft and sticks it through the middle of the rear sproket, then through a hole on the other side of the arm. his R1 has no interference, with the Busa it has a Kotter pin on the right side of that rear sproket in the center of the wheel. I had to remove the kotter pin to be able to slide this metal shaft all the way through to get to the other side of the stand. So it is one piece tubbing that makes the actual stand and one metal rod that goes through the middle and is actually holding the bike up
