removal of nose fairing
probusa
hi all i got good news i have had the twin light convertion put on my bike and will post pics up later.
i need help on the removal of the nose cone i have got led front indicators to put on but not sure how to remove cone could you please advise me.
do i have to take the screen on and the mirrors and wat bolts do i take out the release the cone?
if you can help that would be great
regards
probusa.
You may not have to remove the windscreen. The mirror bolts are what holds the nose on. After you remove the four mirror bolts. (2 on each side) Stand facing the bike and wiggle the nose little by little. It should come off if yo work it straight away from the bike.
I can remove that nose in two seconds!
Did it on my busa Wed morning when I lowsided it into a pole
If you want to use it again however, remove the windshield by taking out the two screws on each side, pull the windshield out and the two rubber things will come with it, take off the mirrors. You also have two push pins on top on the inside of the mirror mounts. Pull out on the sides around the mirror mounts, and when it comes out a ways, unplug the wiring harness on the left side (clutch) side. I think thre relay is on the left side airduct, or by the battery. As someone has already said, you need to take out the three screws on each side fairing too.
