I have a TRE (using the 4th gear map) installed, and will most likely be purchasing a PCIII soon. Based on previous posts, the TRE is redundant.
I don't understand what would happen if I had both installed? As you can only have one map active on the PC, does the ECU use that same PC map for every gear? If so, then isn't the PC only good for a single gear?
The TRE DOES make a difference with the low-end stumble (I've turned it off, and noticed a difference), so would my PC map fix this?
Sorry for the stupid questions, but I'm just not understanding how the two can co-exist.
