Refrigerator Repair
UncleSteve
Gear good - roadrash bad
Anyone know how repair a refrigerator?
Side by side and the freezer is fine, the fridge side is not getting cool enough.
:banghead::banghead::banghead:
NickSully
Most side by sides that I have seen get the cold air from the freezer side through a damper door. There maybe more than one damper door but make sure they are operating properly and nothing is blocking them and make sure they are not frozen over if it's a freezer with no auto defrost setting. I believe you can set the refrigerator to its coldest setting and you should be able to watch the damper doors open. If it doesn't open and you don't hear the motor trying to open it you could have a bad thermostat which may or may not be directly part of the damper door.
That's about all I know about them. I'm sure someone with more knowledge will be chiming in shortly.
UncleSteve
thanks, that is part of the problem, the freezer is icing up and blocking the pass through. I think the defrost for the freezer is not working .
I don't know what part would be bad. I assume there is a defrost element (part) or thermostat problem.
I have defrosted the freezer several times and it works fine for a week or so.
It is a Genaire frig if anyone else can help
Red05
Check the coils at the very bottom for dirt and dust accumulation, especially in the lower rear area. Most fridges have a grille type panel for air inlet. The grooves in it may be clogged with dirt. If they are fairly dirty, pull it off and chances are the area around the fan that blows on the coils will be covered in dirt also. Clean it all very well with a brush and a vacuum cleaner...you'd be surprised what a diffeence it can make.
markiee43
if its a GE model replace the mother board in the back and that will fix it as long as the frezzer side is cold about a $100 part and 10 mins to replace it :beerchug:
BigBSBusa
Had to do that to mine a couple of months ago. Works great now.
NickSully
I believe on Jenn-Air the heating element and heating thermostat is one unit and it's located on the bottom of the freezer side. If cleaning does not work get me the model of your refrigerator and I can probably dig up a wiring diagram and a parts manual for you. Here's a reference of what a heating element may look like for your refrigerator.
Jenn-Air Heatin and Tempature element
Mr Bogus
Trouble Makers Inc.
I know this may sound dumb but I had a fridge that was doing that one time.. turned out the light was not turning off when the door was closed.. sort of unlikely but at least one more thing to eliminate..
racerV
Did you say something?
Mine just went out as well. Repair guy says the compressor is toast. Will be buying a new one this weekend.
pbghost
last year my defrost element went out and it was icing up...not hard to replace, just took the back cover off, unplugged the heat strip from the controller, popped them out of the clips that holds them to the coil and replaced with the new one.
UncleSteve
I just checked the continuity of the defrost element and it was bad. ordered a new one for $40 online. Hope nothing else is wrong with it.
Pardini
Jennair SXS's have a defrost board located in the upper right back corner of the console. Reach in to the very back corners at the top inside of the refer. There is a finger hole in both corner's, kind of bow the cover and yank it straight out, it's a fight sometimes. Then there are 3 1/4 inch screws one straight back by the filter 2 going up that hold the numbered index plate. Then there are two phillips screws by each light. Remove them all.
Then wiggle and slide the whole console assy gently to the right and drop it down. Don't force it, the thermostat sticks in to the freezer on the left side and you don't want to jack it or the styrofoam up. You'll see the ADC board in in back right held by 2 1/4" screws. Might be in a plastic case or an open board. Thats the problem for a no defrost very sheldom is it the heater. Heater is easy to check with and ohm meter, also check the bi metal attached to the same plug. The bi metal is closed when cold, once it hits 45 to 55 degrees it opens so check it when its frosted.
I'd be surprised if it's any thing but the board.
The board can be checked to by shorting the left two pins together with a screwdriver blade. One is marked LINE 1 the other TEST. With the refer running short them together. The fans/comp should stop and the heater come on. If it dosen't shut off the board is bad. If the rely on the board buzzes it's bad. If the fans stop check for 120 vac at the heater plug-- no voltage the board is bad.
UncleSteve
Great info, I will check it out, thank you :thumbsup:
Thread starter Similar threads Forum Replies Date
Kaptain Kanji Refrigerator light... Random Thoughts 28
Vonderbach When you run out of refrigerator space.... Random Thoughts 7
Skywalker A Note Found Posted Low on the Refrigerator Door Random Thoughts 9
C Had to share this: Repair shop/tuning shop claims my 40K mile hayabusa or any hayabusa motor shot with anything over 20K miles LOL General Bike Related Topics 22
J Got a heck of a deal on a TiForce full titanium 4-2-1 system. Needed a small repair. Gen II Busa Information 8
c10 Gen 2 gauges repair Gen II Busa Information 15
c10 A little BMW repair. Making people happy. General Bike Related Topics 3
greg3852 Clutch slave cylinder repair or replace? General Bike Related Topics 4
kml I need advice on how to repair small stress crack under mirror. Busa problems 9
E 2006 Busa won't start after starter button repair Busa problems 11
G Carbon Fiber repair General Bike Related Topics 4
Jose J Ortega Air Intake box foam repair Maintenance and Do-It-Yourself 10
C 2000 Hayabusa Repair Manual Maintenance and Do-It-Yourself 0
B Tiny Crack In First Gen Front Fender, Want To Repair From Back General Bike Related Topics 10
M Fairing Tab Repair Gen II Busa Information 17
Ezz1r Coolant Reseviour Pin Hole Repair Maintenance and Do-It-Yourself 3
S Looking For Inputs On Gen I Transmission Repair / Replace Busa problems 7
S Need Procedures For Maintenance / Repair? Maintenance and Do-It-Yourself 0
T Value Guide Repair Maintenance and Do-It-Yourself 4
V-Max 2 Busa Traditional Open Bi-lateral Inguinal Hernia Repair With Mesh Random Thoughts 5
C Repair a warped brake rotor? Maintenance and Do-It-Yourself 1
A Suzuki GSX-R1300 Hayabusa 1999-2013 Service Repair Manuals General Bike Related Topics 1
HRJR Gen1 Steering Damper repair/replacement Maintenance and Do-It-Yourself 4
GEARJAMMER crossover delay timer $145 repair General Bike Related Topics 4
L I need a repair manual for 2005 Riding Skills/Survival Techniques 3
M Maintenance / Repair in Orange Co, CA .....pls offer good shop Busa Mods 5
caspernz Puncture repair kit - what are you using? Maintenance and Do-It-Yourself 13
L Las Vegas repair shop recommendations? Busa problems 0
TreyYoung Wills Rim Repair General Bike Related Topics 3
H throtle housing guide in repair Maintenance and Do-It-Yourself 1
blacknight Tire repair or replace General Bike Related Topics 21
blacknight Tire repair or replace Tires 6
C-Dog Radiator Repair Gen II Busa Information 14
Mason357 Free repair work Pay It Forward - Members helping Members 10
skydivr Looking for 2002 Chevy Silverado Repair Manual Random Thoughts 15
Busa Rookie modding & repair Busa Mods 1
Freechance Repair manual?? General Bike Related Topics 6
Ludicrous Speed Car question: leather seat color repair Random Thoughts 2
fallenarch Crash Repair Chronicle - Pics General Bike Related Topics 52
I GoPro Camera Repair Videos 4
Fastfrog007 Bolt thread repair thing. General Bike Related Topics 10
Hayabusa4life Motomethod Community Motorcycle Repair Shop General Bike Related Topics 5
M radiator repair Gen II Busa Information 3
T Scratch and gouge repair? Maintenance and Do-It-Yourself 7
T Intercooler repair/straighten? Turbo 1
P Recommendations for good repair shops in AZ? Busa problems 0
R Roadside emergency tire repair General Bike Related Topics 9
L Ducati-Style Headlight Repair Electrical Mods 8
cdhoroho Surgery repair w/ issues Random Thoughts 15
StwBusa Best tire repair kit for long journey General Bike Related Topics 21
Similar threads
Latest Bikes
  • Bam Bam
    My Last Little Girl
    • rlmoorex
    • Updated:
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
Forum statistics
Threads
174,441
Members
48,423
Latest member
cheobusa70
