FireMedic
2007 BUSA, 7k miles, brocks aliened, airbox mod, 17/43 gearing, PCV, speedohealer
2nd gear started slipping so I decided to have it repaired and upgraded since the motor would be Work was done by a reputable builder:
-Port/Polish head
-Cams, manual cam tensioner, adj cam sprockets, new cam chain
-Valve Job/springs
-Thin gasket 13:1
-tranny repair undercut all gears
-clutch mod (welded and added an extra clutch ring he said) ?
-wideband commander data logger
-air shifter kit
-direct port nitrous system 50shot dry, schnitzel micro storm controller
I picked up bike from builder and brought it straight to a reputable tuner to get it on dyno
The tuner flashed ECU, got motor dialed in and made a nitrous pull with controller @ 30%
When he went for 2nd pull on spray controller @ 100% something happened and he shut the bike down. The tuner said i needed heavier clutch springs.
I installed a slave support and 3 heavy duty spring with 3 stock springs
I pulled out plates and fibers to look at them and they looked new. The new clutch kit was installed when above work was done.
(Versa HD clutch springs) they looked just like stock springs
I took bike out for a ride and @ hard acceleration in 5th & 6th gear the RPMs seem to climb faster then the bike is moving. I was told 3/3 clutch springs/slave support would fix problem but it hasn't.
I didn't feel much of a difference in clutch by adding 3 HD springs which I thought was strange.
Some are telling me to go all 6 HD springs, others are saying stay with 3/3 and shim all 6 springs with washers.
Bike has a lot of power but doesn't feel like it has the power it should.
Any ideas of what could be going on and how to solve it?
-Port/Polish head
-Valve Job/springs
-Thin gasket 13:1
-air shifter kit
