i plan on taking my rear wheel off the busa tonight, to replace the tire. i've never done this before but looks fairly straightforward. anything i should know before tackling this? thanks james
No not really, it is fairly easy to remove the rear wheel. Just pull the cotter pin remove the nut then the axle bolt. there is no need to remove the brake assemble, but if you do, it will make it a lot easier to get wheel out after everything is removed. I normally remove the 2 bolts holding the brake on then disconnect the brake bar that holds the brake in place. You will problaby nee 2 people to put it back on unless you have a small floor jack that can balance the wheel for you to line up the axle bolt. Hope this helps
Gen 2 Hayabusa Rear Wheel Removal The service manual recommends loosening the rear axle adjuster lock nuts and adjuster bolts. If you do this, you will need to adjust the drive chain to the proper tension after reinstalling the wheel. It is not necessary to loosen the adjuster screws or...
