I was almost to work and noticed my rear brakes are almost non-existent. The pedal is very squishy. Fluid is in the reservoir, no sign of leakage. Should I just try bleeding them once, or take it to the dealer. I assume it is pretty much the same as bleeding any automotive brake. Pump it up, hold it, loosen the bleeder, tighten the bleeder, repeat? Any other thoughts are welcome. I am hoping for some reason there is just air in the line. I just turned 1000 miles.
