Long story short (kind of). I am in the process of building a 1974 Mini with a mid mounted Gen 1 Turbo Busa. The story of the build is on Instagram @barely_a_mini During my first trip to the dyno we floated a valve. I replaced the bent valve and put in a set of APE valve springs. I put it back together and apparently the old set of keepers didn't like the new springs and decided to let a valve thoroughly destroy my head, jugs, and a piston. I rebuilt again. This time I added APE titanium retainers. I successfully got the project tuned and then the car sat while other stuff needed to get done. I got back to the project this week. I had the motor running and I heard what sounded like a timing chain rattle but the sound was emanating from the opposite side of the motor. Upon the reving the motor the sound would go away. I was running Rotella T oil which and decided to do an oil change to Mobil 1 4t Racing 10w-40 to help bring up oil pressure at idle my oil pressure gauge was showing at 6 psi after the motor warmed up at idle (to low IMO). After the oil change the oil pressure went up. The rattle was still present though. I made a few revs and the rattle went away but returned at idle. Then a whine developed and ultimately the motor stalled and would not turn over via starter. My first thought was I dropped another valve and killed my motor AGAIN. I used a borescope and could not find any damage. I spent all day today tearing down the motor to the point of taking the head and jugs off. There is no damage to anything. The valvetrain is still intact. The crank turns by hand (with a ratchet on the crank bolt) but there is a sound (sand be crunched) and some binding coming from the area of piston 1 and 2. After watching some youtube videos on tuning of the crankshaft counterbalance and the sounds associated with them (whining and rattling) I tend to think my counterbalance died and it's bearings are toast. I plan on pulling the oilpan and counterbalance tomorrow and inspect it. After finding no threads about counterbalance failure, I would have to think this is pretty uncommon? My question is, is this plausible? If the counterbalance is not the problem or if its scattered in a million pieces on the bottom of the oilpan I guess the silver lining is I get to learn how to rebuild a hayabusa motor and add forged rods!
Thanks for any help. I appreciate it.
Ryan
Ryan
