Radiator / Oil Cooler replacement
jeffgordons24
My bike being an 06 has seen its fair share of road time, crappy weather, and use / abuse. As a result my radiator and oil cooler look very dirty and have some ugly bent fins.
Any suggestions to repair the bent fins and refresh the look of the pieces
A new oe radiator is $6-700 with performance ones getting even higher.
I am also open to suggestions for moderately priced replacements.
Mr Brown
Engine degreaser and a hose probably do the trick, steam cleaning would be best.
Be careful with high pressure hoses at an angle or you'll bend the fins.
jeffgordons24
Be careful on engine degreaser some eat aluminum . Why not upgrade to a Gen 2 take off radiator ? you can relocate the overflow bottle , get two fans . Many are dirt cheap complete on Ebay .
Whoaaa that is a good idea!! I certainly like the sound of that!
The gen 2 lines up? Is there a tutorial on here for it.
jeffgordons24
Not my best how too video but it has the points to get the job done
Thank you Bryan, I am going to start sourcing the parts for the conversion. I actually found a thread by 1busa and I will need a temp sensor relocated as well.
I will post pics of my trials and tribulations in the process. And once again thank you for suggesting! Now I improve my cooling and rid the bent fins that drive me nuts.
I will list up the oem radiator for cheap on the classifieds.
  • Like
Reactions: c10
Finally after 3 times installing and removing my cooling system is back together with no leaks and nice cool temps!!
Installed the radiator grill
Wired up the dual fans, had to up the fuse to a 15A since the dual fans were blowing the 10A that used to run the single fans.
Hi where did you find the high performance radiator?
Hi. Where did you find a high performance rad
mabupa
Glad to see you being able to check this one off your “ to do” list. Now send those gauges to get blue LEDs installed. Lol
jeffgordons24
Thanks and yes lol I need to do that. The oil cooler is actually off now so I can paint that black too. It looks silly with the radiator black and cooler silver.
I want some nice faces like yours Miguel!
Similar threads
Latest Bikes
Forum statistics
Threads
171,832
Members
47,250
Latest member
TexMexBusa
