insayne-kustomz
I've recenetly been to a motorcycle show where I got the chance to see up close one of the sickest street legal daily driven hayabusas with a claimed 440HP turbo set-up. After a long convo with the nice guy he mentionned that he removed his anti-pollution PAIR 2nd air valve assembly. He suggested doing this when using an aftermarket exhaust system. I have the side effects that require me to get these block off plates and a Power Commander. My question for this is: When removing this unit, there are a bunch of rubber hoses that lead into itself but there is one that goes up somewhere away from this unit. Where does it go and do I need to block off this point?
My second question is pretty simple. How the hell does this guy run without the oil cooler mounted below the radiator while cranking out 440HP ??? Does anyone here run a daily driven busa without this???
These modifications got my curiosity going and I started searching the net where I found all these ''block-off'' plates for just about everything: low profile crankcase breather, thermostat, water pump, etc etc. I'm aware that some are for drag only purposes but I started thinking of how much space I would gain to run my future turbo without having that oil cooler and 2nd air valve set-up (if it truly is reliable)
Thanks to anyone that can help!
