Hi guys. This site is so awesome knowing that if you have any questions, answers are only a post away.
Anyway, did my 500 mile service today myself. Following the threads on the board and the users manual, no problems. Chain cleaning, lubrication and oil change a cinch
Actually found the bike easier to work on than I expected.
Anyway, after changing the oil, I ran a few minutes, waited a couple of minutes and checked the oil level window. It is at the bottom of the acceptable range, not low, but showing close to the "L". I put in a 3.7 qt container I got from my dealer when picking up my filter. Container unopened, no leakage whatsover. So repeated process, ran a few minutes, waited and as of coming inside and putting this post, oil level still showing same.
Any comments? Is the range I'm showing in the oil level window okay/acceptable. Definately put in 3.7 qts and definately no leakage.
Thanks for your help. I did learn one thing, this will be the last time I do anything without stands
. Am going to order a front and rear right now
