All I have to do is remove the 4 bolts on the upper triple tree, Lift it up, Place the lowering block in place, set the tripple tree on top of the block and replace with longer bolts.
Be sure to check the clearance of the brake and clutch lines. Like when you get on it and the front end fully extends.
also,when/if you choose to lower the front. Don't let the tubes slide all the way up until they rest on the top clamp. It will transfer vibration.
