ORBlackFZ1
Hi everyone:
2007 Gen 1 - I am the only owner. I have been servicing my own motorcycles for the last couple of years. On a recent ride, about 15 miles from my house, I stopped for gas and noticed that coolant was being blown out through the overflow reservoir. I called a tow truck and shipped the Busa back home.
Now I am trying to diagnose the problem. I have a Suzuki GSX1300R service manual and have gone through the chapter on "Cooling and Lubrication System". I have also gone through this forum and found some interesting information. Solutions ranging from new radiator cap to new head gasket. I would like to be able to properly diagnose the problem before I spend time and money replacing parts that aren't broken.
My question is concerning the post by Kiwi Rider here Post #2. When I got to his step #4, I never saw any movement in the coolant in radiator. Should there have been some movement, since the water pump is always pumping? Or should the coolant only move after the thermostat has opened?
Which way does the coolant flow into the radiator? Is it in the top (right side) and out the bottom (left side)?
I was planning on following the service manual for problem identification, but the coolant not moving didn't make sense to me.
I don't have any coolant leaks, so I was going to skip the coolant system pressure test. I would like to test the radiator cap to see if it is bad with my MityVac, but I would have to order the radiator cap attachment.
After the radiator cap, I think the next step is to test the thermostat for proper operation. I can follow the Service Manual instructions and heat it up in a pan of water with a thermometer.
It looks like the water pump would be next. Any suggestions on determining if the water pump is working properly?
The Service Manual lists a "Engine Coolant Temperature Sensor". I am guessing that is for some indicator light on the instrumentation panel and wouldn't be contributing to my problem.
Any help would be appreciated.
Thanks,
Eric
Thanks,
Eric
