Problems
Cireous
Im ready to blow this dam thing up. I got a 2000 Busa. I changed out the ECU 02’, wire harness 06’, start switch 06’. Everything comes on lights, fuel pump. No FI codes. I hit the start button and nothing. No crank. I’ve checked all my connectors and switches. I’ve checked the starter solenoid. Everything is good. Anyone got any clue???
Do you hear the starter relay click when you hit the start button? check at the relay you should have a ground signal at the relay coil and when you hit the starter button you should have 12v on the other side of the relay coil. if you don't have the 12v check the engine kill switch, you should have 12v at the switch, also check the side stand switch and turn signal/ side stand relay. It's also best to make sure bike is in neutral.
It sounds like you replaced the right handle bar assembly (starter/kill switch). Not sure if the left handlebar assembly (turn signal/brights) is necessary, but the wiring is a little different between 00 and 06
