scooterlord
got my pc3 usb today, installed it all ok. run the program try to install map. when i did i found out that it was for a 2002 hayabusa and not my 01. now i can't install a different map for my 01 because it says incompatible map version! help
i have double yoshi rs-3s and k&n filter. the map i found in powercommander.com says yoshi rs3 and stock or aftermarket filter. will this work ok? help me unload this map i loaded and put the other one back on!
the pc3 map i installed was 02 yoshis and aftermarket filter. will it be so much different than the 01?
i think i saw somewhere that you can convert a pc2 map for use in pc3usb how can this be done? sorry i don't have enough time to search atm, my bike is opened and it's about to rain
