Power Commander PCIII USB or PCV
tatt00edangel
I have a stock 2003 Hayabusa that I'm installing Brock's Alienhead exhaust and KN filter. Otherwise everything else is stock. Which Power Commander should I go with and why, Power Commander PCIII USB or PC V?
Thanks
The PCV will allow for future performance upgrades like O2 sensors, multiple map capabilities if you run NOS or a Turbo and more. You will not have that with the PC III USB. But if that is all you are going to do to your bike the PC III will work fine.
I think I will go with the PCV, it's only $10 more and if there's no downfalls, at least I have the option of doing more later on.
you can call brocks and speak to EJ for more advice if you want some but as well I would go with the pcv you never know what the future will bring.
