Bob,
I've had mine on for 700 miles with the Micron and have alternated between your rev1 setting and Micron's original, neither has presented the problem you speak of and my only complaint is the slight dip in the power curve at around 3-4k rpm. I am quite sure my power dip is simply air/fuel ratio that is typical of the loss of backpressure and the motor leaning out due to the free-er flowing pipe. I have never experienced the bike cutting out with it stock or after any mods I've made as so many of you dreadfuly describe and I'm approaching 2k miles.
For the record I just have the Micron with the race can and the pc2 and I'm at 5800 feet elevation. I've notice your modified Micron rev1 map is closer to clearing up the power dip described above but only WHEN THE OUTSIDE AND BIKE TEMP IS COOLER. I reverted back to the Micron map and though the dip is much worse when the bike is cold it seems to work very well and all but goes away after it's warmed completely and on warmer days.
Since I seem to have the only busa not having problems short of the Micron exhust leak (they say my new head pipes are on the way?????) and bought mine very late into the production year here's my last 7: 2103790
Rob
Rob
