I'm trying to instal the gear/speed input cable. found some info but still confuse, have any body here installed this cable. i think i'm looking at the wrong things in the book, i don't think i need to dissasemble the clucth to get to that wire.
here is the instruction from power commander
1.Locate the signal wire of the speed sensor Connect BROWN wire from the HUB harness to the wire tap.
2. If your bike has a rotary gear position sensor then you will need to determine which wire from the sensor is the signal Connect the GREY wire from the Gear Position Hub harness to the wire tap.
thanks
thanks
