Power Commander Map Q?
fastbusajay
Alright... since the search feature is disabled, I must result to asking without searching...
I just installed my Yoshimura R-22 "Bling" Full System...  I need a map.  I don't want to take it to the dyno yet, as there is more stuff I want to do to the bike... so I was curious if anyone had a map for this particular setup.  I do have a K&N Filter as well.
Just FYI for anyone interested, on a stock map, the difference with this exhaust is great!  It is quiet enough at idle to still think, but aggressive and low enough when you getting on it to know the power is just a twist away!
Thanks in advance.
running downloaded maps is hit and miss... you will probably find that a map that isnt even labled for your set up will make your bike run better. I did for me anyway. I have stock filter, no mods to the airbox and full Akro system and the map i'm running has nothing to do with the mods i've done.
