Absolutely it's a big plus. I put one on with STOCK exhaust and it made a tremendous improvement. I will be posting dyno numbers soon when I get the full exhaust but I'm feeling like the PC5 was as much gain as the full exhaust will be.Any benefit from a Power Commander if I’m just running Yosh R77 slip-ons?
If you have one already, can get one cheap, or plan on a full exhaust in the future, I'd do it.
A custom (dyno) tune is hands down the best way to go, you'll need either a piggyback (PC5 etc) or ecu editing for either. Which you choose is probably a matter of opinion, there are benefits to both.No intention of doing a full exhaust, just wondering about any benefits otherwise. I was thinking maybe the OEM map might not be optimal due to EPA considerations instead of solely peak performance. Or I guess an Ivan’s (or other) flash is an option too. Don’t mind spending the money as long as it would improve acceleration, torque, etc.
Give Frank a call at Power House! I wish I had found out about him before I had purchased the Two Brothers Juice Box years ago. I make good power but he was able to tell me the benefits & further management with the PC5 in about 6seconds. Wasted $ now have to change over, flash & dyno tune which will get even better performance can't wait to get the before & after numbers. Seriously he lives this every day he can save you a lot of wasted time & money gets expensive when buying same parts 2 or 3 times.No intention of doing a full exhaust, just wondering about any benefits otherwise. I was thinking maybe the OEM map might not be optimal due to EPA considerations instead of solely peak performance. Or I guess an Ivan’s (or other) flash is an option too. Don’t mind spending the money as long as it would improve acceleration, torque, etc.
Good move I was going to have Shintz flash my ECU then thought what am I doing Frank is on the org. & does not have you check off a few items on a generic order sheet to figure out what you need/want done. With him you know it will be done right and not just assume it was because they put a sticker on your ECU.Good advice. I emailed Frank earlier this week and decided his flash is likely all I need for my purposes. Riding tomorrow morning, then will pull the ECU and mail it off to him.
and also… frank answers phone calls... helps out when u need help... old school stuff....Good move I was going to have Shintz flash my ECU then thought what am I doing Frank is on the org. & does not have you check off a few items on a generic order sheet to figure out what you need/want done. With him you know it will be done right and not just assume it was because they put a sticker on your ECU.
