<div class="iF-Passage"><div class="QUOTEHEAD">Quote:[/Quote]<div class="QUOTE clearfix"><span class="quoteBegin"> </span>
I was wandering if someone on here has any advice on polished frames?[/quote]
I used a variation of this:
http://forum.caswellplating.com/showthread.php?t=1755
I didn't use a sander nor polishing compounds. I sanded it smooth using 80 to 2000 grit sandpaper and then used Mother's polish in the end.
Is it fairly easy to do? [/quote]
I can't answer yes or no as it depends on what you call "easy". What I can say it that it is very time consuming and very messy.
Does it cost a fortune to have it done?[/quote]
Not if you do it yourself.
Is it easy to keep clean? [/quote]
I normally hit it with Mother's every month of so. The Mother's polishing ball will help in terms of time.
I have seen several on this site and they look real good all shined up. I have an 06 blk/grey, do you guys think it would look good or better than it does now with a polished frame and swingarm? [/quote]
Matter of opinion, but mine is it will look better.
Does anyone have an 06 same color with this already done?[/quote]
My '05 will give you an idea:
https://www.hayabusa.org/forums/?act=ST;f=6;t=52887;hl=
Thanks for any info and sorry for all the ?'s
[/quote]
Don't hesitate to send a PM of you start on it and need some advice.
