crotchrocket81
Hello Everyone, I can use any help I can get with my very Weird Instrument Cluster Problem,
I have a 04 hayabusa that recently started acting up , I ll try to describe what it does:
I turn the ignition on, the speedo will do its usual test, then will stop at 9000 rpm, and at 280km/H and the needles will stay there for about 5 seconds, then will continue their trip to the end and then stop and start shaking like a seismograph for a second or two then go back to normal. then when I crank it everything locks up, nothing moves a bit, my digital displays shows everything they can show (8888888) at once. then if I turn the engine off, everything goes up normal...
over here the dealership is useless, they have one motorcycle mechanic, that I don t trust they pretty much specializes in scooters and small bikes.
so I called a friend of mine with the same bike, and took my Speedometer and put it in his, and it works fine, and just out of curiosity put his cluster on my bike, and it acted up the same funny way.
please I feel like at on a dead end, any ideas or suggestions will be highly appriciated.
thank you very much
thank you very much
