PIAA LED fog lights
johnnyo
Hello all, thought I would share some photos of my Piaa LED fog light install. I chose the 60 deg beam fog light because I felt I needed a wider brighter beam down low, helps in corners at night, plus more light in daylight for the for the four-wheel crowd. Had to fab brackets, but everything else was included, harness, adhesive mount weather-proof switch w/LED indicator lights, and a relay, even though you really don't need it with the low current draw of LED lights. Had to extend the harness a few inches, but all else was a breeze. $268.00 thru Amazon--Questions, comments??
Regards, John
semi
Whoooosh!
nice job :beerchug: how do you like the light improvement at night?
RedBusarider
Is the light output adjustable?
Is there a switch for on-off or do they just turn on like the headlight?
Have you had them long enough to tell if vibrations move the aim of them?
Also can you post a link to the product?
Thanks - they look good :beerchug:
johnnyo
The light improvement at night was the reason I installed them, first time I rode the bike at night I was surprised at how poor the lighting was in sharp corners.....
johnnyo
Light output is not adjustable, there is a separate on-off switch, and no, they don't seem to have moved......
here are links--http://www.piaa.com/powersports-lamps/ps-led-lp530.html
Amazon.com: PIAA 73530 530 LED Fog Lamp Kit with Two 3W LED Bulbs: Automotive
Latest Bikes
Forum statistics
Threads
173,392
Members
47,943
Latest member
VikingWeightlifter
