Pc5 Autotune How To Enable Gear Maps Gen. 1
K Wolf
I have a PC5 and an Autotune AT2000 installed on my Gen. 1 busa. I want to have correction and trim tables for each gear. What do I need to do to enable gear specific maps? Do I need to add any wiring for speed sensing, or does the AT2000 use the stock gear positioning sensor?
Thanks in advance.
Contact Dave in tech support @ dyno jet . What I remember , but not 100% is you tie into the gear indicator . When I ran auto tune on my FJR I just chose a set AFR for WOT , and a leaner AFR for cruise up to 4200 RPMs with 0 to 20% throttle for Fuel economy . Anything above 4200 RPMs or 20% throttle opening it went to a richer AFR for power . This worked very well for a full system bike with air box mod / Filter .
