Quart
So, since I'm changing transmission chain and so on and the engine it's unloaded off my good Busa, I'm about to take off the Pair Valve system and lock closed all the holes.
Question I don't find a 100% ensured reply is: for my Hayabusa 2001 (same as 2000, 350kph speed-o-meter, the unlimited one), is there any issue with engine's computing regarding this removal?
Does CPU lights the (FI) if I remove the PAIR? I've been checking up and down the pair valve yet to find a frigging electric sensor regarding that.
Since I will be sealing the Airbox I should have a slightly air pressure increase.. no worries about?
In short words, Do I have to reprogram the centraline or bypass with bridges on some pins or something like? Can I just take that useless valve off and GG?
Thanks and good work
