My 2004 started overheating when idling or at stop lights. but the reservoir level was fine and the fans came on on time.
I searched the forum and came up with lots of useful info, especially about how critical it is to bleed all the air out of the system and how to best do it.
Also a number of members noted issues with the cap radiator sealing and that made sense because air should not have gotten drawn into the system. Plus the level in the reservoir didn't seem to change. The rubber sealing area on my cap was a little eroded so I bought a nearly new cap. (Hey, the bike's 15 years old, I didn't want the other parts to get jealous.)
After a run on a hot day, I let it idle for 10 minutes and saw it dripping coolant from the cap area. I disconnected the reservoir hose from the radiator and blew into it, expecting bubbles in the reservoir but no air would pass. Expecting the hose to be pinched somewhere, I disconnected it from the reservoir but the hose was fine.
The bottom of the reservoir was plugged solid. I guess bits of aluminum or other material eventually settled at the bottom and became glued together. I removed the plastic reservoir (2 screws) and cleaned it with soap and a long wire. All better now.
Then I thought that this could be a common problem, and maybe it's the reason many people thought their caps were bad.
Therefore this post -- in case it helps someone.
[Suzuki should have made the hose port start up a little on the side instead of at the very bottom]
