Hi.
I need some desperate help and advice please.
I have a 2004 K3 Hayabusa which has covered 28,000 miles. When i bought it it had an overheating problem which the previous owner didnt tell me about. It materialised that the cooling fan was shot so I had that replaced with an original Denso fan. In trying to resolve the issue I've changed the following:
1. Thermostat.
2. Fan relays.
3. Radiator cap.
4. Radiator fan switch.
5. Had the original radiator tested by Ready Rads in Birmingham, they say the Rads in good order.
6. New Fuchs coolant.
7. Fuses.
However even after all that I still find that when I get caught up in slow moving traffic my temp gauge rockets to red and if I dont turn my bike off then coolant starts to spout out and leak from the radiator cap. When the bike is on a run it performs beautifully and the temp sits just below half. The fan works as it kicks in as soon as the temperature reaches half mark.
When I bought the bike the cooling fan connector had been disconnected and 'shorted' with a piece of metal between the two connections. The fan wasnt working at all then but now thats resolved.
Im at a complete loss and sooo frustrated. Ive spent alot of time and money trying to put this right and dont seem to be any closer to resolving the issue. Im afraid that it might be the radiator itself but I cant afford to carry on throwing money at it and still not be any closer to a solution. The only things I havent changed are the water pump and rad itself...
Can anyone please help??
Thanks in advance.
1. Thermostat.
2. Fan relays.
3. Radiator cap.
7. Fuses.
Thanks in advance.
