Shaun Ketterman
Hey Folks,
Don’t know if it’s best to do it this way, but I didn’t want to create a bunch of threads if I could just use one as a running log for troubleshooting a couple issues.
Making some good progress on the 07 Busa since I bought it, but still have the following issues to work out:
1. Idle – Since I bought the bike 2 weeks ago, it’s had a fairly rough idle. At running temp, in neutral/clutch pulled, the idle will fluctuate by ~300RPM on a constant basis. I also tested it in 2nd gear, going about 20MPH, and even if I hold the throttle steady, it still does it. The bike will gently lurch forward without any change in throttle, and then back down again, constantly. So far I’ve ran a few bottle of SeaFoam in the gas, I’ve manually cleaned out all 4 throttle body’s (sea foam on a rag, wiped them down, and also sucked some into the vacuum hose, hot soaked it for 10, etc), new air filter, new spark plugs, oil and filter. None of these have solved the issue. Is this the way Busa’s idle? Am I trying to fix something that isn’t broken?
2. Front Brakes – This one is pissing me off. So over the weekend, I did a bunch of maintenance on the bike. All the stuff above plus fork oil, fork seals, replaced clutch and brake fluid, took the calipers apart and scrubbed them completely with degreaser, cleaned all the brake parts with brake cleaner, and put it all back together.
Got the bike put back together last night around midnight. Woke up this morning, went for a ride, front brake performance was terrible. Worse than the rear brakes. When I got home, I noticed the right side rotor was covered in black residue (oil, fluid, don’t know). So I took the calipers off the front, removed the pads. They were black. Cleaned them, roughed them up with some sandpaper, scrubbed them some more. Scrubbed the rotors to get all the crap off of them, and put it all back together. Went for another ride, front brakes still bad. Got home, and now the right side rotor looks like this:
Definitely looks like one of the pads is somehow covered in oil/grease/something again. Is this indicative of a leaky caliper? This wasn’t happening before the weekend. Brakes were great. When I took the calipers apart, brake fluid went everywhere. I had a 2012 Ninja which did not do this when I took the caliper apart, so I don’t know if this is normal for a Busa or not. If that is the case, maybe I didn’t torque the star bolts tight enough, and brake fluid is seeping onto that one pad? I checked my fork seals for leakage, they are perfect, and I don't have any motor oil leaking anywhere that I can see. Brake fluid is the only thing I can possible imagine is the culprit, but...??
3. Spark plugs – Do old plugs look this dark?
Guy at the dealership claimed he swapped them out prior to selling, and I’ve put a couple hundred miles on it at most. The exhaust on the bike when I bought it was just straight pipes. No muffler, so I suspect that may be contributing. I will say, though, that even with a set of cans on there, the smell from my exhaust is very strong. I’m wondering if I am running rich, and if so, what I should look at for troubleshooting?
As always, any and all info is greatly appreciated! Thanks for reading,
Shaun
Shaun
