Gonna try and make it short and sweet. Start by placing on a rear stand if you have one, I have had to do mine on the kick stand which works well too. Remove the cotter pin from the castle nut on the rear axle. Loosen the castle nut. Loosen the lock nuts on each tensioner. Slowly tighten each tensioner until you have about an inch of play on the bottom section of chain. If you look at each tensioner, there are little tic marke to help you keep your rear wheel straight. Once chain is where you want it. hold the tensioner bolts with one wrench and tighten the lock nut with another. Keep an eye on the tic marks because when tightening the lock nut, the tensioner may move on you a bit, just loosen and reset. Onse tensioners are tight, tighten castle nut watching the tic marks still. If the move make your adjustments and retighten. After castle nut is tight, recheck chain and if it still has the inch of play, put in a new cotter pin in castle nut. If it needs it, relube the chain and your good. This is the way I have done mine, but if someone knows a better or easier way, by all means give a suggestion. Hope this helps.
