When you check the fuel pressure, make sure fuel pressure remains constant at all rpm ranges, + or - 5 psi, when you shut the engine off, the pressure should not drop more than 5 psi after 5 minutes, if it does the fuel prssure regulator is bad. That will not cause a problem driving, when the pressure regulator is bad, that will cause extended crank time. To isolate a regulator problem or a injector problem if the pressure drops after shutting off the engine, pinch off the line from the pressure guage to the fuel tank, if it continues to drop, then you have an injector problem. Hope this helps.
Good luck,
Brad.
