Hi all, need to pick your brains again. My busa has a oil leak, the leak appears to be coming from the drain plug so a checked to crush washer and the threads to make sure that there are no cracks in the oil pan or the oil plug. What I noticed is that the oil pan it self appears to be sweating oil. I've check the oil cooler lines and send unit. Now here is the catcher, it only leaks and or sweats when I have the oil level just below the full line on the oil window. When the oil level is below the low mark on the window the leaks stop. I checked all of the oil pan bolts, oil cooler line bolts, send unit and oil plug. Please help and or point me in the direction to check other locations to stop this leak.
Thanks for all of your help.
