celticBandit
Hi Guys,
I really need someones help on this. While changing the oil the other day I noticed an oil leak from the cable that comes out of the stator/alternator cover. The oil is not coming from around the gasket or the rubber but it looks like it is coming up through where the cables go through the rubber grommet. The cables have a nylon heat resistant insulation and it looks like the oil is wicking up through the nylon. (See the coloured cables in the picture)
Has anyone seen this happen?
Can you buy a new cable seperately? or does it come as part of the stator assembly?
I am losing only a little oil over time, it is not dripping, but the oil is wicking up the cable as far as the connector where it goes into the loom.
Any help is appreciated.
Thanks
Tony
Thanks
Tony
