What's up fellas,
I've got a 2000 BUSA with over 35k miles on the clock and recently it begain leaking oil out of the bottom of the stator/altenator cover. I'm speaking of the black cover on the left side of the bike as you sit on it. There is a hole cut out of the fairing for it.
Anyway I know it is leaking there, but the problem is it seems as if the oil leaking from there is blowing back all over the motor back as far as my mid exhaust pipe and to my swing arm. I have sprayed the entire bottom end of the motor down with brake cleaner and taken it out for a ride and when I get back home the oil is all over the bottom of the motor again...It only seems to leak if I put alot of load on the motor, but it won't spread the oil around if I just run it in my drive way...I'm hoping that the oil is being blown or sucked all of the motor, cuz I hope it's not leaking from anywhere else.
Has anyone else had there stator/altenator cover leak and experienced this much oil blow by? I've got a couple of gaskets on the way...I'm gonna use 2 gaskets and some Hylomar from Permatex to hopefully cure the problem.
Thanks in advance!
<!--EDIT|btreaves
Reason for Edit: None given...|1096207683 -->
Thanks in advance!
<!--EDIT|btreaves
