Oil leak when "winterizing" 2010 busa
Hello Everyone.
I have a 2010 'Busa and I am really hoping I didnt mess something up while winterizing it.
I followed the procedures to the T in the manual.(1.run bike with some fuel stabilizer in tank 2. pull plugs, put teaspoon of oil in each bore. put in plugs, crank engine a few times. 3. fill engine right to top of filler hole with oil) I even used a syringe to measure the amount of oil to put in each cylinder.
I put the plugs back in, and cranked the engine a few times, like it says to do.
Later on a I noticed there was some oil on the floor. where I had her parked. I didnt think anything of it because i thought maybe i just spilled some.
So i wiped the oil off the floor and off the body cowling. So fast foreward to now i go to bring it back to life again.
I pulled the plugs, put some paper towel over the top of the spark plug holes, put the bike in 6th and turn the wheel (like it says in manual). Then i pulled the paper towel off and only 1 of them had oil on it and it wasnt very much. then, to my horror, i see oil on the floor and dripped down over the headers.
so my question is, did i blow something up by putting oil in the cylinders and then cranking the bike? if i did then why the hell does suzuki have it as a procedure in the manual? or is this normal? is there some kind of drain on the head for the oil to escape through?
I started the bike and let it run for about 10 mins and it smoked like crazy. then i shut it off, waited a while and started it up again. once again i let it run for about 10 mins. smoke was still bad but started to dimish. then i took the bike for about a 30 min ride. it is running perfect and seemed to have all its power although i really never tried it. (no more than 1/3 throttle and never over 7000 rpm.)
i came home and parked it. put some cardboard underneath and so far there is no oil on it. it has been about 1 1/2 hrs now.
i looked in around the engine everywhere and there was only one placed that looked like it was leaking oil. there is this little hex head bolt/plug on cylinder 4 and cylinder 1. as well, before i rode it looked like there was a little trail of oil comming from the collector tube on one cylinder.
I am really nervous i wrecked the engine. has anyone have any ideas, or ever had the same thing happen?
any help would be much appreciated.
Hello Everyone.
