Oil change question
cycleman
I'm ready to do the first oil change and not really looking forward to removing all the cowling pieces. Somewhere a while back I remember reading that there was a way to get to the oil filter without removing all the plastics. Now I can't locate that thread. Anybody clue me in on any shortcuts? I've read about guys breaking the clips off of the panels when trying to remove them and I want to avoid that risk if possible.
ekz
it is a sticky - a must for your first removal. be patient.
Payne
Just remember be VERY patient, I broke off one plastic bracket but to my luck it wasnt really "needed" so when I put it back it fit like a glove.
Again, be patient, its fairly easy, its a pain in the ass, but its easy.
Schism
this was a "bastid" for me to figure out the 1st time so the best advice i could pass on is, when re- installing the side cowl, start from the top front and work your way down and back. you should slide the side cowl on the plastic rod that is located under the "turn signal" area first and then button that up from top to the bottom where the front wheel is to line everything up nicely. yeah, it's a bit confusing but you'll understand what i mean once you start messing with it. good luck!
The Big Red One
The busa is a plastic nightmare :banghead: I run sysnthetic oil with a factory filter and long life coolant, and change the oil filter every 2 oil changes like the manual recommends, so my plastics don't come off very often....just the way I like it :thumbsup: Some guys have said you can loosen the lower fasteners, and pry the side panel out enough to reach the filter without having to remove the whole thing. If I were a constant oil changer, I'd seriously consider trying to tastefully make some kind of oil filter access hole in the side panel.......maybe something with a removable cover/screen :laugh:
mr8ball
This is the way i did mine the first time i changed my oil. I took the bottom fasteners out and out the filter came. The next time i took it all off just to see and its really not that bad. I have yet to get the left side off. I tried and it became to much of a hassle so i gave up.
Payne
I just came back fomr my oil change. Definitely better then my first time, still its an absolute nightmare when youre pulling on the plastic for it to pop out, I thought i was gonna break it in 8 places. Fortunately it all went smoothly :) Nothing but riding for the next 2.5k miles.
JUSTANOVA
after you get all the bottom fasteners etc... loose/off pull the top rear of the fairing out to pull the peg out of the grommet (it is just above the radiator cap in pic #11 of the power point in the fairing removal thread) once that peg is out slide the fairing foward instead of just pulling it down the slots that the fairing "clip" into are tapered on the front edge so if you slide it forward about an inch the fairing will slide down and out.
hope that makes sense and helps.
mattipetteri
it takes about 27min me to change oil and filter to K8 (full R77 exhaust)
just clocked that time last weekend on my friends 18000km service
dadofthree
Seasoned Beef
Damn. And I thought taking the fairing off my '03 was a pain in the ass...good lord.
I had heard it was a nightmare, but it was actually easier than my '06. Then I read all of the thread. So next time I'll skip the part with the bolt.
Bosshound
Just Take Off the Bolt that holds the Bottom Piece of the Fairing Next to the Back of The Exhaust. Pop the Rubber Piece out and slide the Old Filter Between the Bottom of the Fairing and Engine. Re-Install the New Filter in the Opposite Way............ Drain and Repalce Oil. 15 Minutes MAX.......................:thumbsup:
CCbusa05
And don't forget to line the top plastic inners with masking tape! Maybe even go one step further (if you're anal about scratches like I am) and run a strip of tape along where the top of the cowl meets the upper piece. Oh, you might want to also dab a little vaseline on a Q-tip and coat the inside of the grommets for easier removal next time.
Thread starter Similar threads Forum Replies Date
B Stupid oil change question General Bike Related Topics 23
C6amar9O 500 mile oil change question New Owners Forum 11
Tdog Oil change question Gen II Busa Information 17
Speed King Oil change question General Bike Related Topics 16
justa-busa-girl just a quick oil change question Gen II Busa Information 13
I Question on my Oil Change New Owners Forum 7
B oil change question again General Bike Related Topics 11
U OIL FILTER CHANGE QUESTION... Maintenance and Do-It-Yourself 8
TulBusa help..oil change question after 23 miles Maintenance and Do-It-Yourself 14
Z Oil change on Gen 2 2017 Maintenance and Do-It-Yourself 10
mattymatt716 2018 Oil Change Gen II Busa Information 12
J Clutch Slipping After Oil Change? Busa problems 40
rubbersidedown Oil change time Turbo 22
B Hayabusa Oil Change - modded schedule - milages Maintenance and Do-It-Yourself 56
ottafish Oil change on a M109R - light humor for Friday Off Topic 2
U Why do I need to do my break in oil change at 300 miles for my 18 cbr1krr? General Bike Related Topics 7
Lastfalcon19 First oil change on 2019 Hayabusa. General Bike Related Topics 22
David Offor Fork seal and oil change. Maintenance and Do-It-Yourself 24
Johnnie Phatt all this plus you can get Kiwi to do an oil change on your Busa Random Thoughts 12
ItsDooomz New Busa, 1st oil change and a few upgrades General Bike Related Topics 16
Lewis 2015 Hayabusa Oil Change Maintenance and Do-It-Yourself 23
Davidvon Oil And Filter Change 2006 Gen. 1 Hayabusa Maintenance and Do-It-Yourself 1
Davidvon 2006 Gen 1 Hayabusa Oil And Filter Change Videos 1
newman Oil Change. General Bike Related Topics 20
E Oil Change General Bike Related Topics 9
B Change Oil Gen II Busa Information 16
T oil change and servicing the bike in general Maintenance and Do-It-Yourself 12
ScottyE 600 mile oil change did it myself and saved 220 bucks Maintenance and Do-It-Yourself 12
ScottyE First oil change done now having shifting problems Busa problems 8
MisterGDBusa First service, 230$ for oil change and check up. Gen II Busa Information 41
POWERHOUSE Change your oil General Bike Related Topics 15
E Oil change ? General Bike Related Topics 12
07BUSA420 I am gonna change the oil AND FILTER on my 07 Busa. What else should I do? New Owners Forum 6
Busabim AMSOIL MCF10W40 Oil change---bike running cooler... Maintenance and Do-It-Yourself 6
C 600 miles and first oil change with a few questions General Bike Related Topics 5
POWERHOUSE How to change the oil filter on your rcc turbo bike Turbo 2
M First oil change Maintenance and Do-It-Yourself 8
kml NSA Prism civil liberties pentagon climate change and peak oil Random Thoughts 16
K Oil change Gen II Busa Information 8
banditzx10 busa gen 11 coming up to 3000 miles oil change whats the best Gen II Busa Information 17
H Can i change oil filter without draining oil? Gen II Busa Information 7
adamnflorida oil change problem Gen II Busa Information 25
M Thinking of doing an oil change for the first time. General Bike Related Topics 29
Z Oil filter change Maintenance and Do-It-Yourself 5
Stilslo No more synthetic oil change interval debate for me now Maintenance and Do-It-Yourself 42
lankeeyankee Removing oil from cooler during oil change. Maintenance and Do-It-Yourself 15
Eddie Got my first oil and filter change done tonight Gen II Busa Information 9
ky busa Gen2 first oil change (pics) General Bike Related Topics 11
R Oil Change how often with Mobil 1 4T Synthetic? General Bike Related Topics 35
H How often do you change oil when drag racing 1/4 Mile 8
Similar threads
Latest Bikes
  • Bam Bam
    My Last Little Girl
    • rlmoorex
    • Updated:
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
Forum statistics
Threads
174,442
Members
48,422
Latest member
Verdell1
