C2 has the below additional adjustment
With this adjuster you can adjust high and low speed on the Compression side. Both are adjustable separately in wide ranges.
hi all
wish to check beside changing the whole suspension.
any other alternative eg changing of the spring?
if yes. what is recommend and my weight is 75-76kg and will be having pillon once in awhile.
when i go touring i will have 2 "monster" H&B side box of 40L to ea side.
