OEM parts guide for Gen I and Gen II
ks-waterbug
Group Buy Guy
Gen II CLICK ME
GEN I (below)
ALL LINKS IN BLUE ARE CLICKABLE...
Wheels/Tires
Front size 120/70/ZR17
OEM Tire Bridgestone BT56 J Spec
Rear size 190/50/ZR17
OEM tire Bridgestone BT56 J Spec
Chain
Stock length 112 links
Stock brand RK GB50GSV Z3
(AML)
DID
Brakes
OEM Front (320mm DiscTokico - Front twin 6 piston calliper) -
OEM Rear (240mm Back single 4 piston calliper) -
(AML)
All your Braking needs - CycleBrakes.com oRg Sponsor
Sprockets
Front teeth 17 - SPROCKET, ENGINE (NT:17)27510-21A31
Rear teeth 40 - SPROCKET, REAR (NT:40-530)64511-24F01
(AML)
Headlight bulb
Highbeam 9005
Lowbeam H7
(AML)
HID oRg Group Buy Sponsor - XenonKing.com
Turnsignals
Front/Rear K5/K6/K7 BULB (12V,21W) 09471-12186
Front/Rear K4 BULB (12V,21W) 09471-12045
Spark plugs
Factory - NGK CR9E or DENSO U27ESR-N
Aftermarket
Battery
OEM Yuasa YTX12-BS
(AML)
Air Filter
OEM FILTER FILTER ASSY 13780-24F02
(AML)
PiperCross
K&N
BMC
Oil Filter
OEM
(AML)
Scotts Performance - Part #?
K&N - KN-138 or KN-138C (Chrome)
Fram - ph6018
K&P Engineering - S2 (Re-usable)
STP - SMO-018
PerfForm - J509
Purolator - ML6818
Wix - 51359
Amsoil - SMF109
NAPA Gold 1359
HiFlo Filtro HF138
Oil 10W40
Oil Change 3.5 qts
With Filter Change 3.7 qts (But most members run close to 4 qts)
Overhaul
OEM
(AML)
Amsoil
Mobile 1
Clutch
Rear axle nut size
Metric 36mm Torque 72.5 ft lbs
US 1-7/16"
Front axle nut size
02-07 24mm internal hex head,
and from 99-01 you should be using a 27mm
Torque for Pinch Bolts 16.5 lbs-ft
Torque for Brake Bolts (Front) 28.0 lbs-ft
Body Panel numbers
Micro fiche - oRg Sponsor / MRCycles. com
Micor fiche - oRg Sponsor / MotorSportsSuperCenter.com
AML After Market List
FOR ALL YOUR MOTORCYCLE NEEDS CLICK ME!
Please help feel this chart in.... Post up anything you see missing or just want added
I feel like an idiot, I can't read the diagram right and confused as to what parts I really need.
