G-S
Hi, first post here, from Norway
Have a 2011 Busa, and ordered a Akrapovic 4-1 exhaust on ebay.
Removed original pipes and the catalysator (heavy thing..!), and mounted the lambda sonde in the new Akrapovic.
I have not yet found anyone here in Norway to help me remap the ECU, still looking/asking around.
Maybe I need to take the bike to another country to get it done..
My question here now;
-will the signal from the lambda cause the stock ECU to produce a very lean fuel mix to compensate for the missing catalysator? With possible damaging the pistons?
Should I unplug the lambda?
Is it safe to run the bike as it is now?
And another question;
Should I replace stock airfilter with hi-flow filter, will it help produce significant more power?
If so, I must of course change this before a remapping
Best regards, Gerhard
