Neil Beeston
Hi all, I have a K3 with a starting issue.
When you press the electric start you get nothing, not a click and no cranking (obviously)
I have fitted a new battery and have good voltage from it.
When you switch on the ignition, the fuel pump kicks in,the lights are strong and the neutral light is showing green. I get the F1 light on briefly but that goes out after a second or two.
I've taken the left side infill panel off and checked the starter fuse along with the fuel pump, all read ok on a multimeter.
I don't know where to locate the starter solenoid to see if that has a fuse, can anyone help?
The bike has been stood for some time covered but has been serviced.
Any help appreciated.
