madkidmike
So a little history, a little everything.
New member and this is my first post. I have been reading a tone on this site for months. I was big into circuit racing but recently got into drag racing. I went from a track R-6 to a 03 stretched 45 dry shot NOS Hayabusa drag bike.
My problem:
I have an air shifter that is manually actuated using a toggle horn switch. The system uses the NOS for the air pressure. It has a Carolina Cyclers regulator, MPS ignition cutout and a fuel cutout (just replaced, ran every mil sec possible).
When shift with air from first to second at high rpm I am getting caught in neutral. Every other gear is fine. Low RPM I fine. I have tried everything, It just keeps get caught in neutral. I can manually shift fine.
This system worked fine for a long time. I switched out front and rear sprockets and have had the problem since, I might have had one good run. Everything is hooked up correct. I have adjusted my ram in every position possible.
I am completely at a lost at this point.
I am located in Cincinnati.
My problem:
